3pt hitch interchangeable 40, 50, 60 series
tree frog
10-01-2005 19:32:11
Is the 3 pt hitch on the 40 series interchangeable with the 50 or 60 series tractors?
G/MAN
10-02-2005 12:27:50
 Re: 3pt hitch interchangeable 40, 50, 60 series in reply to tree frog, 10-01-2005 19:32:11
What do you mean by "interchangeable"? If you're talking about large-frame tractors (4640 and larger), The 40-series and 50-series hitches are pretty similar in design and operation. I assume you're talking about the big tractors, seeing as how there weren't any small-frame 60-series tractors. I don't know if the rockshaft housing off a 4840 would fit on a 4850 or not, though. The 55- and 60-series hitches are a different animal entirely - no hydraulic draft sensing or mechanical rockshaft valve on those - they use a potentiometer to sense draft and electronic solenoids to control oil flow to the hitch - a much simpler and more reliable system. The small-frame tractors continued mechanical draft sensing and valves right through the 55-series.
Tx Jim
10-02-2005 03:42:38
No
