4010 injector pump timeing
jbking
10-01-2005 07:27:00
can any one tell me which is the number 1 cylinder on a 4010 diesel? according to the firing order and counter clockwise rotation of the pump it should be the rear cyl. (next to steering wheel), but my shop manual refers to the front cyl. (radiator side) as no. 1. so which do i use.
thanks john
HTR
10-01-2005 12:21:09
 Re: 4010 injector pump timeing in reply to jbking, 10-01-2005 07:27:00
What Bob sez, and the pump is considered clockwise rotation, determined by viewing from the drive shaft end. For static timing, you need to determine which pump you have. Options are, original load advance pump, up dated to speed advance, or pump set up for 4020.
Bob
10-01-2005 08:12:16
#1 is at the front, nearest the radiator, where is is on 99.9% of in-line engines.
Wouldn't be much of a shop manual if you couldn't rely on it for such a simple question, would it!
