45 Combine engine stuck or something
E Deci
10-01-2005 07:20:26
I just got this combine. It ran for a few minutes and stalled, probably from bad gas. Also needed a battery. New battery, cables and solenoid and it won't turn over. All I get is a whack when the starter engages and tries to turn her over. Oil level looks OK, it was not hot when it stopped, there is nothing in the upper cylinders - plugs look fine, etc. There appears to be some sort of "clutch" on the rear of the engine that is part of the mass of pulleys that drive off that end. Is it possible it is locked? I am new to this setup, but normally have no trouble figuring out these old engines. I did try to pull the machine in gear and it would not budge.
Leroy
10-01-2005 14:07:47
 Re: 45 Combine engine stuck or something in reply to E Deci, 10-01-2005 07:20:26
That clutch; a moveable pully; is the clutch for the seperator. Also the 45 combine used a total of 5 different gas and at least 1 deisel engine so machine and engine nos, may help. Machine made in Hi, Hi-Lo, and square back versions so that could allso help. And the clutch on front of engine is for grain unloading auger. Does the machine have power steering?
E Deci
10-01-2005 16:07:47
 Re: 45 Combine engine stuck or something in reply to Leroy, 10-01-2005 14:07:47
I did not expect such fast responses! Great! The serial # on the combine is 49273 H, and it has a cab and does have power steering. The motor number is a bit beaten up but I get:
51-HA (Hercules gas?) and MAYBE 006287X next to that. The block has T26932 casting number on it. I believe this is a square back model, as it is slanted a bit, but not curved in any way like others I have seen.
I am not at all familiar with combine controls and considered that some lever had moved while I was driving, but changing positions of different things has not made any difference, so I figure it is a "problem" rather than just my ignorance!
The one shop I stopped at just teased me for having the thing in the first place, "I hope you didn't PAY anything for it". Not really relevant at this point! I happen to think the darned machine is rather beautiful in a retro contraption sort of way. Was gonna use it at the farm on a small 10-15 acres section, but now that it has demanded so much of my attention, I may decide it is a parade piece that I can use to attract attention to my farmers market business.
Any help anyone can offer will be greatly appreciated.
Glen in TX
10-01-2005 18:33:13
 Re: 45 Combine engine stuck or something in reply to E Deci, 10-01-2005 16:07:47
45s were made in 1954 to 1969. Lots of variations like Leroy said. Yours should be 1968 model as #49001 was beginning of 68 and #51001 began 69. Manuals listed for the 45 combine 46001 on up are:
OMH63137 Operators Manual (46001- )
SM2054 Shop Manual (Jan.'67)
PC652 Parts Catalog (Feb.'69)(covers all 45s)
You might find other variations of the manuals around used on ads or ebay. Can get new copies of the JD manuals by calling 800-522-7448.
MSM
10-01-2005 12:02:48
Couple of possibilities,starter is stuck in the flywheel,maybe try turning engine backwards,or remove or loosen the starter,or one of the accessories that is driven off the engine directly siezed a bearing or got jammed.If it didn't stall like it had a load on it,I doubt it is internal.
msb
10-01-2005 19:13:15
 Re: 45 Combine engine stuck or something in reply to MSM, 10-01-2005 12:02:48
I am with msm on this one.You mentioned it needed a new battery.Starters will malfunction with low voltage a lot of the time.I would pull the starter and see if you can turn the engine over by tugging on the drive belts with the starter off.You may have welded a connection in the solenoid.
