4010 D block
Jack-Iowa
09-30-2005 14:34:50
Just curious can a JD 4010 D block freeze and crack enough to allow the weep holes to leak water.Or would it leak oil as well? And I am assuming that it was full of water as if it was only half full there would be enough places for the water to go without exertng force on the block.
Make sense or not?
thanks
rotten robert
10-01-2005 17:25:14
 Re: 4010 D block in reply to Jack-Iowa, 09-30-2005 14:34:50
It is common for 4010"s to leak coolant from the weep holes. This is caused by the O" ring around the sleeve deteriorating with age. New sleeve kits now come with three o"rings and you can put an o" ring in the middle groove in the block.
Mike M
09-30-2005 15:42:38
If you are only leaking water out of the weep holes then I would think you just have normal oring erosion. I would not want to bet that a block only partial full of water could not split as I have seen many 2 cyls. with just the bottom of the head broke because they were drained then the plug put back in and enough water still drained down in to freeze and break it.
