JD 60 block casting number
Jesse Minor
09-30-2005 14:06:08
Just looking to see if a A3703R engine block casting number is correct for a 60. I was told it was from a late A.
105Diesel
09-30-2005 14:32:24
 Re: JD 60 block casting number in reply to Jesse Minor, 09-30-2005 14:06:08
Nope, that cylinder block won't work in a "60". Model "A" Tractors serial number 648000-up and Model "60" Tractors used a cylinder block with the casting number of A4320R. The A3703R cylinder block was used on Model "A" Tractors serial numbers 584000-647999. The bolt pattern is different on the A3703R block, and won't bolt up to a "60" main case.
Mike Aylward
09-30-2005 14:52:51
 Re: JD 60 block casting number in reply to 105Diesel, 09-30-2005 14:32:24
I'll chime in with my two cents here. The A3703R block WILL fit into a 60 tractor. The only difference between it and the later A4320R block is the early block does not have bolt holes in the bottom that come up through the frame. The A4320R block is the factory replacement for the late A block. While the A3703R block will physically fit into a 60 it is better to get the later block as the extra bolts will support the block better if heavy front end equipment is used. Mike
Mike M
09-30-2005 15:47:10
 Re: JD 60 block casting number in reply to Mike Aylward, 09-30-2005 14:52:51
Look at the back where they bolt up the later A and 60 have 1 more bolt hole added also.
Mike Aylward
09-30-2005 17:45:04
 Re: JD 60 block casting number in reply to Mike M, 09-30-2005 15:47:10
The 3703 block IS the late A block. The '47-49 A's take a block with the fewer bolt holes. Mike
Mike M
10-01-2005 05:00:24
 Re: JD 60 block casting number in reply to Mike Aylward, 09-30-2005 17:45:04
I was going by the serial numbers listed by 105diesel above ? I better look in my own parts books just to clear this up in my own mind. thanks Mike
