Coolant Leak 620
Tree Topper
09-30-2005 13:44:28
I have a 1957 620, it is getting coolant in both clylinders. It starts fine with a little white smoke out of the exhaust.We pressure checked the cooling system but could not make water run in the clylinders, so we put air pressure in the clylinders. It would not bubble out of the radiator. This tractor was rebuilt back in about 1990, bored .045 over, replaced head because orginal was cracked. Tractor was pulled for a few years, but not ran hard. I am assuming that it has a blown head gasket or maybe a crack somewhere. The tractor does not heat as we are using it to pull a disk for gardening a little now. The question that i am asking is, is it possible for water to get in the clys from some other source? . I know that some of the old B John Deeres had some push rod sleeves that would rust through and let water in. Any ideas thanks.
w
Mike M
09-30-2005 15:54:45
 Re: Coolant Leak 620 in reply to Tree Topper, 09-30-2005 13:44:28
If your coolant is going down and you are sure you detect some in the cylinders since the tests you did do not seem to make it go in the cylinders than maybe ? try to retorque the head.I'd also dump in some bars leak.
