'49 A starter engagement
Dave in SV
09-30-2005 11:22:54
Sometimes, when depressing the starter foot-pedal, it sounds like the starter drive is not engaging the flywheel ring gear... starter spins, but I hear an awful "stripped gears" sound, and the engine does not turn over. I read somewhere that the ring gear's teeth beveled edge should be toward the crankcase. I looked at mine... nope, beveled edge is AWAY from the crankcase. Is this my problem? If so, how do I turn the ring gear around?
Pappy
09-30-2005 15:14:34
 Re: '49 A starter engagement in reply to Dave in SV, 09-30-2005 11:22:54
Inspect the starter drive to see if it is actually engaging in the flywheel teeth. If so, the starter drive may be bad. It has an internal clutch that can give way. Mine did the same thing a couple of times. I took the starter drive off and cleaned it with mineral spirits and got all the dirt and grease out of it. Now it works.
Dave in SV
09-30-2005 20:16:02
 Re: '49 A starter engagement in reply to Pappy, 09-30-2005 15:14:34
Thanks for the idea. I had the starter rebuilt recently, including a new clutch drive... so I don't think that's the problem. With the battery disconnected, I watched the engage action while I depressed the pedal. The starter gear did not mesh the ring gear teeth. I realize that this is not a real accurate test, since the starter isn't spinning under this test (which would normally assist with the meshing process?), but it makes me think that the reversed ring gear is (at least part of) the problem.
John T
09-30-2005 11:43:03
Dave, you may wanna take a look at how much side to side end play there is in the flywheel/crank. If its too much the starter drive may not be engaging far enough over into the flywheels ring gear. To take the ring gear off we lay the flywheel up on oak blocks and use a torch to heat all around the ring for it to expand then use punches to drive it off. After its repaired or reversed or whatever may be required its replaced (again using heat to expand it) but NOT in the same location as most of the wear occurs in that one particualr range of teeth. It may be required (if reversed opposite from how it should be) to grind or file each tooth so as to allow the starter drive to mesh into the rings teeth.
John T
Dave in SV
09-30-2005 20:20:47
 Re: '49 A starter engagement in reply to John T, 09-30-2005 11:43:03
Crank endplay is fine. I wondered about adjusting the rod that connects the pedal to the starter drive assembly, to result in a deeper mesh of gears. But after taking the flywheel cover off and watching the mechanism action, I don't think that would be the right move. I am leaning toward the ring gear being on backwards as the culprit. I will use your suggested method and turn the ring gear around.
Thanks.
