JD 45 combine high/low versions?
Ian T
09-29-2005 20:45:06
Curious too know what the differances are between the high/low versions of combines. I recently bought a 1959 45 combine. How do I know what version i have ?
Stan - Florida
09-30-2005 10:24:38
 Re: JD 45 combine high/low versions? in reply to Ian T, 09-29-2005 20:45:06
Here's just one more input.
From an April 1955 brochure on the 45 combine, it lists "Height Over-All with Grain Elevator Folded for Storage - 9 ft,10 in.. Height over-all (operating) - 12 ft., 9-1/2 in.
From an August 1959 brochure on the HI/LO combines (referring to the 45 model), "Over-All Height (less folding radiator screen) - 8 ft., 8 in.
The quotes listed below about the high operator's platform and low, compact lines for easy storage and transport are probably from the same brochure.
Stan
dirtjockey
09-30-2005 09:05:53
My 1959 Hi-Lo brochure shows a round back combine It states; "The new idea for the Hi-Lo design gives you a HIGH, confortable operators platform that puts you up, out of dust and chaff-away from engine heat--LOW, compact lines for easy storage and transport and for greater stability".
TBSCOTT
09-30-2005 08:33:51
I think the hi/low refered to high capacity...low overhead clearance. I have a couple 45 round backs that are of the hi/low era.
billyiron
09-30-2005 05:32:37
dont know a lot about JD combines, but thought the HI-Lo had a slope bottom grain tank,also flat backs,,
Leroy
09-30-2005 18:34:48
 Re: JD 45 combine high/low versions? in reply to billyiron, 09-30-2005 05:32:37
The hi-lo filled the hopper with an auger thru the hopper where the hi had a slide shute from the elevator to fill the hopper and all hi & hi-lo were round back with 1964 and up being refered to as square backs. I have a 62 & 63 hi-lo and a 65 & 69 square back
