24V Information
Tech 7
09-29-2005 18:16:19
Would appreciate some input on testing the starting/charging system as used on the early 4020 and similar models. I do have access to tech manuals but would like to know if there are any short cuts that will utilize the test equipment hat is available today. Thanks, Bob
Tech 7
10-02-2005 19:07:31
 Re: 24V Information in reply to Tech 7, 09-29-2005 18:16:19
Thanks for the replies .... I think you said it best with the article "understanding" the 24V system. I will look it up and print it Thanks,Bob
WTW
09-30-2005 11:02:49
Tech 7, The best advice is what has been previously given. There is many "short cuts" / test that can be performed but without the knowledge on how the system works and functions the test information can be useless or even misleading. If you get a good understanding of how theses system work testing it will be simple. To help you with this do a search on this topic "Understanding 24 Volt Systems" and read the piece I wrote on it a few years back to help you get a better grasp of it. It isn't perfect but if you can understand and work on 12 volt systems this additional information should really be helpful to work on a 24 volt John Deere system. If there is something you don't understand after reading it post back and I will try to explain and help you some more. Good Luck, Dave Wickman
jdemaris
09-29-2005 18:52:04
The issue is too complicated to provide a thorough answer in this forum. The system is not a conventional 24 volt system. It was custom-designed for Deere by A.C. Delco and enables the tractor to use two 12 volt systems, side by side - one 12 volt system being negative ground and the other positive ground. Cranking, of course, is 24 volts. The integrity of the system relies on two core issues that can, and do cause problems. Number one, the starter must NOT become grounded through the metal frame as are most other starters. It MUST remain isolated, but what happens over time is the accumulation of dust from the brushes collects internally and starts to cause such a ground. Number two is a balanced load on both the 12 volt systems, e.g. if you hook a headlight to one side, put one on the other also (or an equivalent load). You don't need any unconventional equipment for diagnosis, just knowledge.
