Fan - ventilator pump, early 60, no power steering
Don c
09-29-2005 12:15:23
The housing tube the shaft runs in has oil seeping out the back O ring where it goes into the pump, how much work and how much trouble will I have just changing the O ring. Thanks Don c
Mike M
09-29-2005 13:09:03
 Re: Fan - ventilator pump, early 60, no power stee in reply to Don c, 09-29-2005 12:15:23
That little o-ring is a major operation ! You'd have to pull out the fanshaft,which will also mean pulling the governor off too.Or go at it from the front and pull the radiator. Then the entire fanshaft assy. is going to have to come apart. If you had a know gov. or fan problem it would be worth it you could go in and fix it all at one time. But just for that oil leak ???
