Deere Diesel Piston in big six?
Mopower
09-29-2005 09:33:30
What is a big Deere diesel engine that has close to a 4.75 bore engine? A 521? Is that right? I am not a Deere guy. All I know is the 404.
JDBert
09-29-2005 10:30:05
 Re: Deere Diesel Piston in big six? in reply to Mopower, 09-29-2005 09:33:30
Mopower, at the bottom of the page, theres a guy that just pulled his 531 apart and got new pistons, if you wanted to use old ones might be worth a try. Under 5010 pistons (JonathanT-user handle)
WTW
09-29-2005 09:54:32
531 is a 4.75, 619 is a 5.125, 404 is a 4.25, 466 is 4.56, 359 and 414 is a 4.19, 329 is a 4.02 and a 303 is a 3.86. DW
Mopower
09-29-2005 10:03:08
 Re: Deere Diesel Piston in big six? in reply to WTW, 09-29-2005 09:54:32
That's what I needed to know. A 531 piston will work in a Minneapolis Moline 585 engine with my crank and rod update modifications modifications. Thanks!
Glen in TX
09-29-2005 14:46:36
 Re: Deere Diesel Piston in big six? in reply to Mopower, 09-29-2005 10:03:08
There will be 2 different style pistons for 531A turbo engine and 531D natural aspirated. Also later ones were changed from 4 rings to 3 rings and pistons weighed different so have to be a matched set. Hmmmm in 585 MM. Takes green of all kinds to make them run huh? lol
Mopower
09-30-2005 04:40:24
 Re: Deere Diesel Piston in big six? in reply to Glen in TX, 09-29-2005 14:46:36
Thanks for the info. Yeah Deere parts and service is pretty hard to beat when you are used to dealing with salvage yards (no offense to you salvage yards). Collectors are my best bet. M-M pullers used Detroit Diesel Parts, I-H, Case, Deere, Aircraft, CAT, and more for pistons and rods that work in combination.
