JD 420S Single Touch-a-matic
NC-Ron
09-29-2005 09:05:17
1956 420S. Local JD dealer put new seals in hydraulic unit and I had cracked rockshaft housing repaired. Worked OK for about 20 minutes, then could not get it to lift. Would this be a valve or cylinder problem? Pump seems to be OK. Where can I get procedure to check out this unit? What else do I need to look for?
Henry J
09-29-2005 12:52:34
 Re: JD 420S Single Touch-a-matic in reply to NC-Ron, 09-29-2005 09:05:17
NC
Watch out for that cracked rock shaft housing. What usually causes that is incorrect adjustment and the crank inside the housing goes beyond designed limits and cracks the housing.
It is all there in the service manual
