47B leaks oil
Jamesdrd
09-29-2005 06:23:13
I found another flywheel to replace the cracked one put it on runs fine, leaks bad on flywheel side took flywheel back off, not leaking around shaft, dont leak when not running, while running without cover oil sprays everywhere
Pappy
09-29-2005 20:20:56
 Re: 47B leaks oil in reply to Jamesdrd, 09-29-2005 06:23:13
You need to look at a service manual to fully understand the proceedure, but there is a seal inside the spacer behind the flywheel. It is a cork seal and can be replaced. Most likely, this is where the oil is coming from. Also, there is a drain hole under the slinger inside the bearing cover. This hole must be clear so the oil drains back into the engine.
Mike M
09-29-2005 12:04:20
Did you line up the square pin in the back of the flywheel with the square hole in the oil slinger ?
Jamesdrd
10-04-2005 04:50:03
 Re: 47B leaks oil in reply to Mike M, 09-29-2005 12:04:20
didnt know about the cork seal ($3.92 from JD)
the old one looked like it was part of the cover hard as steel the only reason it didnt leak when i got it was because of all the grime covering everything,installed the new one last night& dont leak no more, thanks for the help
