JD 3020 D with Bad Engine what's it worth?
TD
09-28-2005 20:26:39
HI Looking at buying a Early JD 3020 Diesel with a cracked engine block, has syncro trans, WF, 3pt, what is something like this worth $?
Thanks in advance
TD
09-29-2005 19:03:22
 Re: JD 3020 D with Bad Engine what's it worth? in reply to TD, 09-28-2005 20:26:39
It is cracked at the rear of the block near the cly. head. Can you please send info on where to send it to get it welded?
Thanks
msb
09-29-2005 18:30:20
Where is the block cracked? We used to have them welded, even the webbing between the cylinder bores.Like the other posters mentioned, the balancer block could be a bigger problem if it is bad.
buickanddeere
09-28-2005 21:21:01
If you can find a cheap 2510/2520. You have all the parts to drop in a good but cheap Dubuque 239 or 279 into the 3020. The salvage yards and dealer shelves have been stripped of 3010/3020 balancers etc.
Bob-Wyo
09-28-2005 20:51:47
TD about 5 years ago I bought a early 3020D PS,3pt, WF with broken crank and cam, paid 500.00 and had over 6,000.00 in parts when done, block and head is about all I saved of the engine, then new paint and tires. Hope this helps some,
Bob
