'44B main bearings
Steve M.
09-28-2005 14:00:41
My machinist says he needs to remove .010 from my crankshaft main journals on my '44B. It has adjustable mains.Do I need to buy .010 undersized main bearings? If so, where can I find a set? Thanks for any help,Steve.
DickD
09-29-2005 02:23:42
 Re: '44B main bearings in reply to Steve M., 09-28-2005 14:00:41
Steve; I have a good crank, if you decide to go that way.
Mike M
09-28-2005 17:20:24
If your crank is bad enough to need ground then those bearings should show alot of wear and cannot be reused even if the crank was built back up to standard. Make darn sure you can still get bearings before doing anything. How bad does your crank look and did he give you any measurements ? I only ask as from past experience about all of the machinists you will find are used to working with engines that idle at what yours maxes out at.So they also think that they need to meet the specs. of a modern engine but they do not these old slow speed engines and babbit bearings are very forgiving. If your is indeed shot new bearings may not be available so don't rule out finding good used parts as many B's were built and the cranks hold up very well.Usually an oil pump coupling failure from water in the oil freezing is about all that does them in.
Miller49G
09-28-2005 16:38:06
Steve M,
Yes you need .010 undersized main bearings for the crankshaft. When I had my 49G crankshaft redone my mains were fine but the rod journals had to be turned .010 undersized. I don"t know were you can get .010 undersized mains. But my rods had babbitted type rod bearings so I had them rebabbitted .010 undersized.
Miller49G
