300 hydraulics
GH in OH
09-28-2005 08:28:14
Hello all,
I just purchased a JD300 backhoe and the hydraulics seem pretty slow. When i first start the tractor, things seem to work well, however, after i use it for a few minutes, things start to slow down. I have changed the hydraulic oil and filters. In addition, i had the oil cooler checked. (thought it may not be cooling the oil enough) Now i am stuck and don't know what to look for. I reallize this is an older backhoe (i think 1974), but i thought it should move a little faster. Just wondering if anybody has any suggestions as to what i should check. Thanks in advance for all the help.
Mark Thomas
06-08-2006 11:36:49
 Re: 300 hydraulics in reply to GH in OH, 09-28-2005 08:28:14
GH,
Did you ever figure out your hydraulics? I bought a JD 300 a few weeks ago and it has the same problem of slow Hydraulics.
gh-in-oh
08-31-2006 11:38:09
 Re: 300 hydraulics in reply to Mark Thomas, 06-08-2006 11:36:49
Mark,
I have not had any luck with the hydraulics. I have changed/cleaned every filter/fluid i can think of. I have so many projects to do this winter, but i think this one is going to get moved up on the list. I almost hate to run the machine due to the slowness of the hydraulics. Let me know if you make any progress with yours.
Kansas
10-02-2005 05:54:52
Did you figure out the hydraulic problem on your backhoe? I've got a JD 400 and I've got a similar problem. I was just curious if you happened to get it figured out...Thanks
gh in oh
10-03-2005 08:48:24
 Re: 300 hydraulics in reply to Kansas, 10-02-2005 05:54:52
Kansas,
Still no luck with the hydralics. I did manage to find the sump screen this weekend. It was pretty bad at one end so i cleaned it out (hoping this was my problem) However, after digging for a few minutes, it started acting like it always has. This week, i am going to take ET's suggestions and look for the oil filter bypass valve. If i make any progrss, i will be sure to let you know. Good luck with your 400.
Mike M
09-28-2005 09:43:15
Did you also clean the sump screen ? in the bottom of the tranny case.
gh in oh
09-29-2005 04:32:59
 Re: 300 hydraulics in reply to Mike M, 09-28-2005 09:43:15
Mike M,
Could you please tell me where the sump screen is located? (i know you said in the bottom of the tranny case) Thanks. Hate to be difficult, but i really don't know much about this tractor. Have a good day.
Mike M
09-29-2005 05:38:17
 Re: 300 hydraulics in reply to gh in oh, 09-29-2005 04:32:59
That screen sits crossways in the bottom access to it is a big round plug in the side usually has a square hole in it for a 1/2" breaker bar. Drain all the oil first or else you will get a oil bath. Pull out the plug then pull out the screen and see whats on it ,lots of metal filings could mean brake problems. Sometimes just a thick goo from moisture in the oil. Clean the screen and put back in or get a new one if it is damaged. Cleaning and inspecting this screen is the first step to figuring out any hyd. problems.
If you have a local TSC or Rural King or another place that carries I & T shop manuals get one for a tractor like a 1020,1520,2020 it will help you as much is the same. You can order the correct manuals from Deere but it will take awhile and cost alot.
ET
09-28-2005 09:21:11
Check the oil filter bypass valve. It may be stuck open or need replacing. I had a 301 tractor with lazy hydraulics and it was dumping half of the charge pump oil back into the transmission through that valve.
gh in oh
09-29-2005 04:35:55
 Re: 300 hydraulics in reply to ET, 09-28-2005 09:21:11
ET,
Just wanted to say thanks for the help, but can you tell me where the valve is located? I really need to find a book on this backhoe. Thanks again for your help.
ET
09-29-2005 06:38:10
 Re: 300 hydraulics in reply to gh in oh, 09-29-2005 04:35:55
On the brake pedal side of the tractor just under the platform and in line with the filter housing is a hex plug about 1 1/4" that is the bypas valve. Also behind the filter on the same side of the tractor is a big hex plug with the suction screen under it. Our tractor had a elbo and small hose hooked into that plug. Another thought if you have a gauge the presure valve for the transmission pump is behind the brake valve. It's a hex plug facing the rear of the tractor. The pump should have 150psi at 2500 rpm.
