46A loader on 2510
Lambert
09-28-2005 07:47:41
I am buying a 46A loader that came off a 4020 for my 2510. I am told it will work. Question is, do I need special brackets or anything else to get it to work on my 2510? I am a little gun shy as I kept my 47 loader off my 1020 for the 2510 only to learn I needed different mounting frames and brackets. Don't want to make similar mistake with this. If it works, my 47 loader will be for sale. Thanks
jdman(MO)
09-28-2005 09:05:16
 Re: 46A loader on 2510 in reply to Lambert, 09-28-2005 07:47:41
I have a 46A loader on my 2510. I can send pictures of the brackets, but I thought a 2510 was just a baby 4020. Russ
Lambert
09-28-2005 10:01:26
 Re: 46A loader on 2510 in reply to jdman(MO), 09-28-2005 09:05:16
Thanks Russ. I have been told the 2510 has the same frame as the 3020 and the 4020 is a little longer. Does your 46A mount in the bracket slot closest to the axle? Also, do you like the 46A on the 2510?
Lambert
jdman(MO)
09-28-2005 16:05:06
 Re: 46A loader on 2510 in reply to Lambert, 09-28-2005 10:01:26
The loader is hooked to the same mount as the fender, and is the slot closest to the seat. You pull 2 big bolts to remove it. I like it real well, it has a 6 foot bucket and my control is mounted on the right side on the loader frame. It also has float for backdragging and 2 cylinders for tilting the bucket. I guess I cannot say for sure the brackets are the same as the 4020. Russ
