Is possible to add Reverser?
Charlie1520
09-28-2005 05:58:52
I have a JD1520 that I use a lot for loader work. I see that there was an option to have a Reverser that would let me shift from forward to reverse and back again fairly easily. Does anyone know if this option is something that could be added or if it is a major re-build? Thanks.
buickanddeere
09-30-2005 16:44:19
 Re: Is possible to add Reverser? in reply to Charlie1520, 09-28-2005 05:58:52
It will be cheaper to trade for a tractor with the reverser.
Roy Suomi
09-28-2005 19:13:15
You would still have a high- low trans. But on early models the reverser would not shift into reverse in high range. All you have to do is leave a shift cancelling pin in the reverser shift cover out...Still a big job. You would need a donor tractor to get lines , cooler , linkages, etc...
Mike M
09-28-2005 06:13:16
I think you would be looking at a major undertaking.
msb
09-28-2005 08:47:35
 Re: Is possible to add Reverser? in reply to Mike M, 09-28-2005 06:13:16
Why would you want to do away with the hi-lo feature when the shift pattern on your tractor works so great.
Charlie1520
09-30-2005 05:03:56
 Re: Is possible to add Reverser? in reply to msb, 09-28-2005 08:47:35
I don't have the hi-lo option either but I would still think that having the reverser would be more useful for me using the loader. Thanks for your thoughts.
Mike M
09-28-2005 09:50:15
Wasn't hi-lo an option also ? He may not even have that I see no mention of it ?
