Hi-Lo shifter jumps out of gear
DickD
09-27-2005 19:15:21
I purchased a 42 B today and the owner said the Hi Lo lever jumps out of gear. Anyone had any experience with this? I would really appreciate some input Thanks a lot
ChuckW
09-28-2005 11:38:32
 Re: Hi-Lo shifter jumps out of gear in reply to DickD, 09-27-2005 19:15:21
There are several reasons for this. My first check would be to see if there is end play in the drive gear, the bearing could be bad allowing movement, also the next thing is the detents not holding in position. This shifting has a collared gear messing inside a drive gear. There is an external adjustment for this also, but I would make sure worn bearings are corrected before any other adjustments.
Mike M
09-28-2005 05:39:11
In addition to the adjustments and the detent spring and pawl being worn someone may have been shifting it on the go and rounded off some of those teeth loose bearings can also let stuff move around that shouldn't.
jd b puller
09-27-2005 20:34:05
my 47 does that, but it doesn't have a true HI/LO lever, it just shifts the gear when you bring the single stick from side to side. I haven't had time to see what is causing it.
Dave in SV
09-27-2005 19:32:21
Would there be a similar set-up for the A Model, too?
old
09-27-2005 20:37:59
 Re: Hi-Lo shifter jumps out of gear in reply to Dave in SV, 09-27-2005 19:32:21
Yes if its say a 1940 or older
old
09-27-2005 19:29:05
Yep my 1935 did that. There a place on the left side I think that has what looks like a plug. Remove it and under it theres a very large flat blade screw that needs to be turned in a little. You will need to look a little been 2 years since I did that and don't remember where it is but its easy to do once you find it. Also it takes a 1 inch wide screw driver to turn it.
