720/730 PowerTrowl Pump Rebuild Questions
Tyler-MO
09-27-2005 16:04:21
I"ve got my power trowl pump from my 720 apart now. The parts book subs the original seal AF1925R for 2 -AR21090 oil seals and a R21720R spacer. My question is how should the substitute set up be installed? What goes where (I mean in what order with seals facing which direction)?? My gut reaction tells me that anyone with access to service manual updates from the late 1950"s to the early 1960"s could find a survice bulletin covering this substitution. Please help me out if you can.
Thanks,
Tyler in Missouri
Mike M
09-28-2005 06:08:54
 Re: 720/730 PowerTrowl Pump Rebuild Questions in reply to Tyler-MO, 09-27-2005 16:04:21
Those seals go in back to back lips facing away from each other is how the original was set up. I don't remember using those spacers the ones I got seemed to be too big of dia. to fit in the housing ? plus they may of made the assembly too thick and some stuck out ?
I always had the idea that JD wanted you to use that spacer washer to help hold the new type flimsy seals in place so the pressure wouldn't push them out ? I could be totally wrong ,but I have had them move on me before so I started buffing all the green goo seal coating off the outsides of the seals getting them to clean metal then using hardening pematex or some kinda loctite on them to seal and stick them in place. I also pack the space inbetween the seal lips with grease.
Another little trick I use on those pumps is too clean and deburr the housings and use an ever so LIGHT coating of silcone sealer to seal those machined mating surfaces. I didn't have that good of luck with other sealers.
dirtjockey
09-27-2005 19:42:42
Just thought I would throw this in; if you need a top cover gasket for the power troll you might consider Greg Stephen. He is the only place punching that gasket I could find. No I don't get commission!
The Old Tractor Company Stephen Equipment Company PO Box 709 7460 E Hiway 86 Franktown, CO 80116 303-663-5246 303-468-3077 fax
Dcotton
09-27-2005 17:00:05
Are you refering to the powersteering pump? Because the numbers you list are to the power steering pump. I just redid mine on a 70 and would be happy to share what i found out..
Tyler-MO
09-27-2005 19:27:36
 Re: 720/730 PowerTrowl Pump Rebuild Questions in reply to Dcotton, 09-27-2005 17:00:05
Well, I'm rebuilding the power trol hydraulic pump...but I checked my parts book and both power steering and powertrowl pumps use the same seals. And they both sub to the same seal and washer combination at least for the rear seal....so yes, I'd be interested in hearing what you found out. I'm thinking about putting both seals facing the pressure side on the pump with the washer in between just like the parts diagram on the 530/520 Parts Catalog for the power steering pupm where the newer 2 seal & washer combination is illustrated. Thanks,
Tyler
