Dave, Ifffff fffff and thats a BIG IF, the battery is okay???,,,,, ,,the ground and starter and battery cables and connections are ALL okay???,,,,, ,the mechanical start linkage is allowing the start switch button/plunger on the starter to be fully depressed???,,,,, ,,,, INSURE ALL THOSE THINGS FIRST (if any doubt, I would remove, clean n wire brush and reattach each n every battery n starter n ground cable then try it) !!!!! !!!!! !!!!! !! Theres a good chance the starter switch is bad unless the starter itself is the problem. What that start switch does is make machanical contact from the post on the switch connected to the big battery cable on it to the post that comes out of the starter so current flows through the starter. If when trying to crank it the lights dim wayyyyy yy down badly, then I suspect it could be a bad starter HOWEVER if the lights hardly dim when you try to start it, then I suspect more of a starter switch or a burned up starter terminal/post problem. The starter is located under a removeable tin plate under the tractor and it sounds like youre gonna have to remove that if the battery n cables n connections n grounds and the mechanical linkage seems okay. CAUTION DISCONNECT THE BATTERY CABLE TO AVOID SHORTS Once the bottom tin cover is removed, you can get to the starter n switch. If you have to remove the starter BE CAREFUL AS ITS HEAVYYYYY YYYY First, insure the cable is well attached to the starter switch and its not carboned up etc. If thats okay (and all the above including the battery n cables n connections n grounds and mechanical linkage is okay) youre gonna have to remove the switch to observe if its washer/contactor is all burned up n carboned CUZ THAT COULD WELL BE THE PROBLEM if all else above is okay. Another problem may be the copper looking post on the staters side (where switch contactor mates) is all burned up n pitted !!! I have had some luck by cleaning n light filing them but if they are too badly burned up n pitted you need to get a new starter post on the starter. Check the easy simple things first like battery n starter n ground cables n connections..... ..... ..then insure the cable is well attached to the starter switch..... ...insure the linkage allows the start switch button/plunger to be fully depressed down tight..... ..... ..then check the start switch contactor for being badly burned or pitted or carboned up..... .....then insure the starter post is good n not burned up n pitted etc. Those start switches go bad fairly often and arent too expensive or too difficult to replace. If the starter itslef is bad then youre stuck with a shop rebuilding it. John T in Indiana
