Cycle mower attachment??
Bruddies Pop
09-26-2005 20:20:33
I need info on an attachment for a 7 foot mower that alows you to windrow grain. I have seen them but do not know what to ask for, they have shoes for the cycle bar for a longer stubble lenghth and they have different lenghth hooks that drag behind and windrow the oats. What are they called? Do they work in all conditions? Does anyone have a set? Thanks Pop
CMB
09-27-2005 10:23:55
 Re: Cycle mower attachment?? in reply to Bruddies Pop, 09-26-2005 20:20:33
Wish I had a dollar for every acre of Oats I windrowed with my Dad's '41B. We called it a windrower, ours was a 3/4 delivery, which meant the swath was deposited about three forths of the way to the left, rather than in the middle. We slid the right wheel in till it almost touched the clutch pully, then offset the mower the same by drilling some new holes in the mower hitch(we didn't have a "quick tach" mounting). We then turned the left wheel inside out to make room for the last windrow to pass between the front wheels & the left rear. This looked very strange, but worked extremly well. I always windrowed Oats in 5th gear with this outfit.
RAH
09-26-2005 21:08:42
It was called a swather (sp?). We used it a couple of times for alfalfa and brome silage. Last time we used it there were a few striped cats (skunks) that would plug the mower when you hit them. It was about equally impossible to lift the bar with a foot lift or backup. We took it off and had the neighbor rake after the mower. He kept a sharp eye on the mower and noted where it plugged. These sections were raked in road gear. Right now the swather is setting on top of a McCormick grain binder built during WWII at my brothers. It is about the best use for the binder as it certainly wasn't much for cutting oats. It was much improved when bolted to the PTO of the A via some hardware that I think came from Beresford S.D., may have been Peterson Machine??
55 50 (Ron)
09-27-2005 07:22:59
 Re: Cycle mower attachment?? in reply to RAH, 09-26-2005 21:08:42
RAH, You made a statement "These sections were raked in roadgear." Would you explain that a bit more as I'm confused a bit by it. Especially the word "sections". Thanks
RAH
09-27-2005 09:15:20
 Re: Cycle mower attachment?? in reply to 55 50 (Ron), 09-27-2005 07:22:59
When the mower plugged, knowing there were skunks on the loose, I lifted the bar, backed up a bit to clear the bar, and started out again. Rusty, watched for these spots and shifted into fouth until the rake passed that spot. Section = about 30'.
55 50 (Ron)
09-27-2005 11:18:06
 Re: Cycle mower attachment?? in reply to RAH, 09-27-2005 09:15:20
I believe I understand now. Get in roadgear to pass those dead skunks as fast as possible!
55 50
09-26-2005 20:51:35
First, it's a sickle mower, a cycle is what goes down the road on two wheels (or some of them on three wheels). According to my Parts Catalog PC-466 and Operator's Manual OM-H10-(1-56) for the No. 5 mower, those items are End Delivery Windrower Part A2226H and High Cutting Attachment Part AZ-2312H. Other models of mowers may have something different.
bruddies pop
09-26-2005 21:00:43
 Re: Cycle mower attachment?? in reply to 55 50 , 09-26-2005 20:51:35
Thanks , Ever had that feeling you misspelled a word but your brain won't let you change it! Now it's out for all the world to see..
55 50 (Ron)
09-27-2005 07:19:13
 Re: Cycle mower attachment?? in reply to bruddies pop, 09-26-2005 21:00:43
I always worry that a correction may offend. Glad to see you're OK with it. Hope my other info was helpful.
