JD 175 Loader
David in MD
09-26-2005 04:54:52
I just got a good deal, or so I thought, on a JD 175 loader. Unfortunately it came off a 3 cylinder tractor and I need part numbers W32694 and W32695 to make it fit my 4 cylinder 2030. JD no longer sells these parts. Can anyone suggest any used parts dealers who may have loaders. I'd even trade for someone who wants to mount one on a 3 cylinder tractor.
MSM
09-26-2005 07:06:15
 Re: JD 175 Loader in reply to David in MD, 09-26-2005 04:54:52
If it came off of a utility all you have to do is lengthen the mounts. Either end can be lengthened depending where you want the loader to sit on the tractor.Bolt it on the tractor at where you want it to sit,make a cardboard template,and have a welding shop make up the pieces you need out of the same thickness metal and weld them on to the mounts. Either you or the welding shop can drill the holes. Use Grade 5 or 8 bolts and keep them tight.
