47 B cracked flywheel
Jamesdrd
09-25-2005 19:21:50
just purchased a B got it running real good then painted it put it all back together found bad oil leak coming from behind flywheel cover while trying to find source of leak found old crack in flywheel looks bad on outside hard to find on inside what do i do
johnny t
09-29-2005 21:13:19
 Re: 47 B cracked flywheel in reply to Jamesdrd, 09-25-2005 19:21:50
hi try marlin smith at 712-489-2570 for parts. the flywheel has to be a certain distance from the block in behind it and it has to be set with the clutch in gaged. consult a repair manual if you don't know how to do this. i think the setting is .010, but you need to ask or read up on how to set this.
old
09-25-2005 19:29:55
As Bob says DON"T run it till you do its a big OH NO if you do. If it comes apart it will not only hurt you but it will also hurt the tractor. Or at least could.
Bob
09-25-2005 19:25:36
Replace the flywheel, before it grenades, and kills you, or even worse, kills someone else!
