Lenny: I would get the service book for the engine and go through all of the diagnostics for the fuel system. A quick check that I like to make is to remove all of the injectors, and pivot the lines so each injector can spray out into the air. This can show if they are spraying well, atomizing uniformally, etc. DO NOT PUT YOUR FINGER IN FRONT OF THE INJECTOR SPRAY BECAUSE AT 2300+ PSI IT CAN TEAR YOUR SKIN, RIP OFF A FINGER, OR AT LEAST MAKE A REALLY NASTY CUT. Think about the concentrated spray from a power washer. If they appear to be dripping or sluggish, have them check at a shop for correct breaking pressure and nozzle performance. Then you might have to tackle the pump timing. You didn't say how it came to act this way, or how many hours it has, but it could have had a perforated air filter at one time (which can be catastrophic), the rings might be poor, the valves need adjusted, and these things can cause you to not develop all of the compression you need, or the starter could be slow. But in any event, you first need to get a proper manual. They seem pricey, but I generally save their cost back on my first repair job on a unit. I have used mine to no end on my 855. Frank
