PBrowning posted this in another thread the other day and it"s an excellent way to diagnose carb problems. I"d suggest anyone who might have a carb problem should print it out and put it in the "file". While I"m here I"d like to say "Thanks !". I"ll paste it below : Testing -- LOAD & IDLE Pathways -- A test is conducted to double-check your carburetor"s IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: (1) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. (2) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below. (3) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked
