? on long axles BW
billyiron
09-25-2005 14:19:58
whie back I got a BW but the axles had been cut,,I found a salvage BW with good axles, but they are a bigger diameter,,was this a upgrade or special option, and will they go in my other BW,,,billy
Jake Win
10-01-2005 16:42:08
 Re: ? on long axles BW in reply to billyiron, 09-25-2005 14:19:58
It depends on the year of the tractor. Check your parts book, but in late 50 or 51, not sure of exact serial number, the high clearance BN's and BW's got a larger diameter axle. It is the same diameter and spline count (15 i believe) as an A. It allowed customers that wanted a wide tractor to be able to put more weight on them, such as with a beet diggger or heavy mounted implement. This was only for the High Clearance tractors, with long axle housings.
Dennis in
09-26-2005 13:08:50
Billy,
You did not tell us the vintage of your tractor. I am not near my parts book at the moment, but that information will be helpful. Late-styled "BW" or pre-1947 "BWH"?
Dennis
Dudley R
10-09-2005 02:52:16
 Re: ? on long axles BW in reply to Dennis in , 09-26-2005 13:08:50
The bigger axle (15 spline) was added on the BN & BW at S/N 275398 which rolled out in the 1950/51 time frame.
