Kevin, if the Generators Field wire were OPEN with NO connection from the Gens Field post to ground or anywhere else, that would be an extreme LOW CHARGE state and nothing I see to burn wires up. On those Generators, 12 Gauge should be sufficient, cuz thats not much more if any then a 20 amp output unit. I only use 10 or 8 Gauge if I change over to 60 amp or more alternators. From your description I cant understand if you have a 3 wire (BAT ARM FLD) Voltage Regulator or a 4 wire (BAT ARM FLD LOAD) ????? 1) Check your wiring: 3 or 4 wire VR: BAT up to ammeters Load (NOT to battery/starter) terminal ARM (or GEN) to Gens Armature post FLD to Gens Field Post On a 3 wire VR, loads like lights n ignition are fed from the ammeters Load terminal via feeds from ammeter to the BAT input terminal on switches,,,,, ,,while on a 4 wire VR, those same loads are fed from the LOAD terminal on the VR 2) CHECK GROUNDS Both the Gen and VR need a good ground 3) CHECK FOR SHORTS The VR's BAT terminal wires to the ammeters Load terminal, so be sure that wires NOT shorted nor any other wires. A short in the wiring can cause an overload on the battery or charging circuit, but I suspect it as a battery short (like off either of the ammeter terminal wires) more then a Generator short. However, if the Voltage Regulators internal cutout relay were stuck closed, that can cause A MAJOR SHORT whereby battery current flows through the VR and grounds out via the Gens brushes and armature and it can be enough current to fry light gauge wires !!!!! !! If shes right there should ALWAYS be hot battery voltage on BOTH sides of the ammeter PLUS on the BAT terminal on the VR. However, if the Gens not putting out voltage higher then the battery, the VR's internal cutout relay ought to be OPEN, otherwise high battery current can flow into and out the VR to the Generator !!!!! If a Gen were not polarized it can cause problems initially charging, you may wanna try that but Im afraid you either have her miswired,,,,, ,,or theres a short in the ammeter to VR wiring or elsewhere,,,,, ,,,or the VR may be bad like a bad cutout relay, remember it ought to be normally OPEN and it basically closes the connection between the VR's BAT and ARM (or GEN) terminals. Polarity was originally Positive ground, you still wired that way????? ????? If not all sort of things may be screwed up !!!!! !!!!! LOOK FOR A SHORTED WIRE!!!!! !!!!! !!CHECK POLARITY John T
