4020 PTO keeps running
Phil/PA
09-23-2005 16:48:16
After bushhogging the other day when I disengage the pto on my 4020 it would keep running, not completely, it will stop if there is a load on it but if I start the tractor up the pto shaft will turn which makes it impossible to hook anything up if it is running. This just happened all of the sudden, any ideas.
I did notice when I engaged the pto clutch it seemed a little harder than normal, it would go forward a little and then hit a hard spot and I just pushed harder and it engaged. I didn't force it but it was more than usual.
It is a 1965 (old style, not side console) JD 4020 powershift diesel.
Any idea what caused it and if it is hurting anything.
Thanks,
Phil
Mike M
09-24-2005 17:04:44
 Re: 4020 PTO keeps running in reply to Phil/PA, 09-23-2005 16:48:16
I was thinking those old style 4020's were mechanical pto and not hyd. like the later ones. Get an I & T manual and do some adjustments that may fix it.
lonzo
09-23-2005 19:52:18
sounds like the pto brake dosen't work, there is a pin that stops the pto brake from spinning and has been know to brake off, when this happins you have the problem you got. the brush hog is hard to stop and the brake is applyed buy hydraulic pressure, the brake is on or off no between, that little brake takes a beating from pto implemts that are free wheeling when you shut off the pto at high rpm's, there is one more thing that can be wrong, the pto clutch disc can be dished causing clutch drag, to replace the brake you must split the tractor at the clutch houseing and remove thel clutch pack and 2 bolts that are behind the clutch pack. the rest of the bolts are on the out side. at this time stick the pack threw a hole in the work table so that the big part is up and remove the 3/8ths bolts and the pto clutches are under the plate that you removed the bolts from they need tobe flat and no blue markes where they show signs of slipping, if they do that is a nother story,before you split the tractor it would be a wise idea to check the pto pressure
