4010 questions
Kio
09-23-2005 11:59:27
I am looking at a 4010 with a wide front to purchase. I know very little about them. It runs and is in fair condition. There are little water stains on the side of the block that seem to come out of small holes in the center of the block. Are these the weep holes everyone talks about on here and what else do I need to check on the tractor before purchasing. What is it worth from what I have described?
Thanks for any info.
61-4010
09-25-2005 04:20:48
 Re: 4010 questions in reply to Kio, 09-23-2005 11:59:27
2 years ago I purchased a 1961 4010 knowing it had issues specifically in the engine area. Coolant mixing with the oil. Tore it down the engine and found holes, literally, worn between the block and the sleeves which was caused by coolant cavitation. Had to get a new block and rebuild kit. But the crank, head, etc all were fine. The 4010 is great machine. Easy to get parts. Work horse too. But if you aren't for the "journey" and just want something that runs without much/any work, then perhaps you need a newer machine. As for me, I'm enjoying the "journey" rebuilding this antique machine from the front to back.
Jack-Iowa
09-23-2005 12:53:21
Gas or diesel? welds on the front or anywhere else? Tranny type. 3 pt ,leaks,paint,tin work there?
anywhere from 4k and up.
Yep you are correct weeps holes and if they leak they need new o-rings which will cost some.
Kio
09-23-2005 17:22:56
 Re: 4010 questions in reply to Jack-Iowa, 09-23-2005 12:53:21
Diesel No welds that I could see. The top link hook-up on the tractor is broken in two. It looks easily replaced with a new piece. Tranny not sure. Paint is a farmers touch-up. Sort of green. A few dents here and there but nothing smashed in or missing. The rest of the three point looks fine. Leaks:nothing bad just typical old tractor stuff. No huge patches of bald spots under it where the grass is dead. New alternator. I still need to hear it run, we looked at it while the owner wasn't home, I have talked to them and they said it starts and runs fine. We'll have to see. They live not far from me. Is the weeping a big deal?? Is it real hard to fix?
K
Hayfarmer
09-23-2005 19:12:24
 Re: 4010 questions in reply to Kio, 09-23-2005 17:22:56
The weeping may not be a really bad problem depending upon how much. As mentioned it indicates the O rings on the bottom of the sleevs are leaking. Weap holes there so the coolantruns outside instead of into crankcase wehre it oculd casue real problems. To fix would be an overhaul, remove head and sleeves. Not sure what that costs these days, I'm sure it isn't cheap. While there you need to check bearing. You can sets with new sleeves and pistons, basically update to 4020 stuff. With head off you might as well grind valves. I thought the synchro range transmission was the only one offered, differential lock did not come out until 4020. If it has an alternator it may have been changed over to 12 volt whick is good, but there are 24 volt alternators so will have to check that out.
txgrn
09-24-2005 08:58:12
 Re: 4010 questions in reply to Hayfarmer, 09-23-2005 19:12:24
I agree about this being an ongoing spending spree....once you start you just have to keep spending.
That Deere uses what's called a wet sleeve design. As mentioned the weep holes allow for oil or water to exit the space between the sleeve and the block if the oring in that direction failed. If one fluid is leaking the other may be close behind. My first 4020 had the same problem and I unknowingly bought it. With the subsequent overhaul, the $5000 I paid for it was way too much and it was LP too which should have been another $1000 off. I spent over $1000 on the overhaul and did the work myself and didn't touch everything.
So, unless it is a giveaway price like $3000 I'd walk away smiling (for your wise decision).
Mark
Kio
09-27-2005 08:37:12
 Re: 4010 questions in reply to txgrn, 09-24-2005 08:58:12
Thank you all very much for the much needed info.
