1940 JD clutch will not engage
DWhittemore
09-23-2005 11:58:36
I have a 1940 B JD the hand clutch will not engage,when I push level forward will not move. Can anyone tell me what to do.Is ther a easy eay to correct the problem.??? Thanks Dennis
Duane Larson
09-23-2005 12:45:43
 Re: 1940 JD clutch will not engage in reply to DWhittemore, 09-23-2005 11:58:36
DWhittemore,
Does the engine labor when you push the clutch lever forward? If so, it may be in two gears at once. If that is the case, the cover with the shifter lever will need to be removed and the problem identified. Check the archives here as this problem has shown up before.
Mike M
09-23-2005 12:15:14
Did it work before and just quit ? Anyhow your going to have to take it apart and look for broken and stacked facings and stuck operating bolts or anything else stuck or broken.
