Flow Restrictor Valve
Pete/ME
09-23-2005 02:56:17
The #56 Kelley backhoe on my 4020 is pretty jumpy, and I heard that you can put some sort of restrictor valve on the inlet connection to lower the inflow pressure and smooth out the operation of the control block. Has anyone heard of this? And where would be a good place to find the valve.
Glen in TX
09-23-2005 13:23:14
 Re: Flow Restrictor Valve in reply to Pete/ME, 09-23-2005 02:56:17
If it just needs to go on the hose coupled in a remote any implement dealer or farm supply or industrial supply place will have inline restrictors for that. Also can use hydraulic flow control valves or cushion valves for that purpose. Flow control valve item # 9-6286 or cushion valve #9-4019-A or 9-4019-B from www.surpluscenter.com
buickanddeere
09-23-2005 04:52:42
Is that backhoe returning the oil to the oil filter housing? Is the filter and screen clean? And the biggie, are the controls on the on the backhoe open or closed center? Where is the backhoe hydrualic supply tapped in? From a rear remote or "T'ed" into the main hydraulic line coming from the front pump?
Pete/ME
09-24-2005 02:21:06
 Re: Flow Restrictor Valve in reply to buickanddeere, 09-23-2005 04:52:42
Return piped into the oil filter housing, t'd supply in front of brake pedal...both piped to quick-connects mounted on axel. New filters, screen cleaned, converted hoe valve body to closed center according to manual.
buickanddeere
09-24-2005 08:58:15
 Re: Flow Restrictor Valve in reply to Pete/ME, 09-24-2005 02:21:06
Hmmmm. Looks like you have done everything right. Does oil or air move freely though the backhoe control valve(s) from the HP supply line to the oil filter return line when no valves are open? I have seen high pressure systems where everything was done "right" but resonate harmonics would cause " water hammer". The length of pipe work and the pump pulses per second were tuned to the same frequency. We had to pull the five vane pumps and have custom made seven vane impellers installed. Have you tried different engine rpms? Or a high pressure accumulator similar to what Deere is promoting for their farm loaders for a "soft ride".
Pete/ME
09-25-2005 03:58:14
 Re: Flow Restrictor Valve in reply to buickanddeere, 09-24-2005 08:58:15
Thanks all, I'll try the restrictor valve. B&D, the stuff about harmonics and vane impellers is way beyond me, thanks though, I'll try lowering the rev's but I've got to keep the gauge in the "O.K" zone.
txgrn
09-23-2005 04:02:37
May be as simple as a disc with a small hole in it. Like on JD tractors with high volume pumps. If you want your mower-conditioner (swather) to raise and lower smoothly, you have to restrict the hyd fluid so it can't flow as fast which results in nice slow, smooth, cylinder and resultant implement operation. I know cause I found one in a newly acquired swather. Not knowing what it was nor what for, I took it out. The first time I operated the swather after that I found out. Glad I saved it as it went right back in.
The one I saw (have) has about a .100 hole in a disc that fits in the back of the standard Pioneer NPT fitting. Just unscrew the fitting off the hose and look into the rear of the fitting; or if inserting one insert it in the rear of the fitting and put it back on the hose. Simple as that.
Mark
F-I-T
09-23-2005 08:39:58
 Re: Flow Restrictor Valve in reply to txgrn, 09-23-2005 04:02:37
You can also plumb an old brass gate valve in line and close it slowly until you get the effect you want. Then if you want something that looks cleaner, you can drill a hole in a disk to approximate the same cross-sectional area that the opening that the gate valve had.
Frank
txgrn
09-24-2005 08:59:22
 Re: Flow Restrictor Valve in reply to F-I-T, 09-23-2005 08:39:58
That's work or just leave the valve plumbed in.
Mark
