Bosch fuel injection pump adjustments
Dennis Hibbs
09-22-2005 19:51:35
hello, can anyone tell me how to turn the fuel delivery down on an 8820 combine bosch pump. This is a new purchase by a friend. The timing is correct but the engine crackles too much revs too fast, black smokes, and the exhaust gets red when under much load. the turbo is ok. there is no air fuel ratio control. should there be one? has a plate where it usually belongs looks factory?? Thanks
msb
09-22-2005 20:56:18
 Re: Bosch fuel injection pump adjustments in reply to Dennis Hibbs, 09-22-2005 19:51:35
Simply turning the screw down might not help.I would pull the pump and have it recalibrated.Sounds like the govenor link is out of adjustment.Probably surges or hunts doesn't it?
lonzo
09-27-2005 19:04:52
 Re: Bosch fuel injection pump adjustments in reply to msb, 09-22-2005 20:56:18
there is a square plate at the end of the pump that has 4 bolts that have saftey wire threw the heads, remove plate and you will see a set screw and jam nut, loosen nut and turn screw in 1/2 turn and try it, the screw ls a stop for the fuel rack, back screw out and you get more fuel, the FOS manual for engins tells about the bosch pumps and where to do adjustments for what ever reason
