brake rivet tool
John51
09-22-2005 16:07:14
I have the brake linings and rivets for my 530 and 60 and I should do both. I've riveted new linings on before, using my father's hand rivet tools. However, he's now 83 and doesn't know where they are! Despite all my searching, I can't find them. Where can I buy what I need? Is there a special size? Thanks for any help.
Skyhawk Greg
09-23-2005 21:49:44
 Re: brake rivet tool in reply to John51, 09-22-2005 16:07:14
John, If you go to a flea market, you may just get lucky. I bought a couple of the rivet tools for $3 each about a year ago, and as recently as last weekend, saw some more for sale. This is a longshot, but for what it is worth, if you are near Medina, Ohio, e-mail me at [email protected], and you can come over and use my tools to do your linings Greg
John51
09-24-2005 01:50:46
 Thanks in reply to Skyhawk Greg, 09-23-2005 21:49:44
Thanks but I'm in northcentral PA. I won't do the brakes until winter so I'll keep watching and then maybe buy one of the aircraft supply ones if I don't find a used set.
ChuckW
09-23-2005 12:48:23
I've tried punches but if you're not careful you will crack the lining. Take to dealer. Also I've wondered why pop rivets wouldn't work...guess they might lock up if pin came out.
Rodney A. Johnson
09-23-2005 05:53:48
If you got a set of punches and a wide center punch, that is all you need.
Use the center punch to get the rivet to bell out. Then take a regular punch and flatten.
Usually you need a punch on the back side so you have something to hammer against.
Old trick my shop teacher in high school taught me many years ago.
55 50
09-22-2005 22:53:45
All the other posters have good input. However if you still want to buy your own machine, McMaster-Carr has them, page 2704 in their catalog 104 (the latest one I have but I think they have later catalogs out) and they have a www.mcmaster.com web site. The price for that rivet machine is $47.98 and its catalog number is 6664A4. I bought this riveter in 1996 and it was $41.36 then. It worked well on the brake linings of my model 50.
K.B.-826
09-22-2005 20:27:53
Most all JD dealers still have a brake pad riveter, as just about every tractor newer/bigger than yours require the same tool. Your dealer should be able to do those in about 20 minutes. The labor would be much cheaper than it would be for you to purchase a tool.
Dan in Ohio
09-22-2005 17:46:02
John51, Get a set of transfer punches, 1/4 size works well. You can buy the punches for $10-15. I have done several this way.
Glen in TX
09-22-2005 16:37:46
The one I have fits in the vise or press. The one shown in catalog has a screw type arbor. You might find a single tube rivet tool at a old hardware store or leather supply place or brake riveter at auto supply or let a local shop press them for you.
Paul from MN
09-23-2005 13:14:31
 Re: brake rivet tool in reply to Glen in TX, 09-22-2005 16:37:46
Glen,
I bought a rivet tool from an aircraft tool company. A couple months later I got a catalog for aircraft tools in the mail. When my wife came in from the mailbox with that catalog, she wanted to know what the _ell I was up to now.... She figured I"d taken up yet another hobby.
The tool works great.
Glen in TX
09-23-2005 13:52:35
 Re: brake rivet tool in reply to Paul from MN, 09-23-2005 13:14:31
This link takes you to the brake riveter like I have not the other one. This one is less $ too. This one clamps easily in a vise.
Glen in TX
09-23-2005 13:34:26
Paul, You can always find lots of goodies to add to a wish list in those aircraft catalogs. lol. Was that a Aircraft Spruce catalog you got? www.aircraftspruce.com We use to get the fuel tank liner from those places till less expensive stuff starting showing up. Got some buddies that mess with those little experimental planes but I'm not getting in one yet. lol.
G/MAN
09-22-2005 16:29:25
Unless you REALLY want to do it yourself, most machine-shops have a rivet press, and can put those linings on in a fraction the time it takes to do it by hand. I doubt they'd charge you much at all to do it.
