Rick, not too hard a task assuming the Alternator is really a true "One Wire" and since you have a Magneto. 1) I assume the Alternator is for Negative ground, correct????? 2) Install the 12 volt Battery with its Negative to frame ground and its Positive is what has the big cable down to the starter switch or solenoid. 3) The Alternators big main BAT output post wires to the ammeters LOAD (NOT to Battery/Starter) Heres the deal, if thats really a 100 amp Alternator youre gonna have to drastically rewire the Tractors charging circuit cuz its only like No. 12 Gauge at max and was designed for like a 10 or 20 amp max generator. The old ammeter is more like a 20 amp device, so you may have to upgrade it to a higher amperage unit cuz youre gonna peg it bad with a 100 amp Alternator. Wish you had purchased a 30 to 50 amp alternator lol. You can likely get a generic higher scale ammeter at any auto parts house that still fits in the same dash hole size as you have. Check it out !!!!! !!!!! ! If its a conventional Ammeter with + and - terminals and for a Negative ground,,,,, the + Supply terminal wires to the battery/starter while its other - Load terminal wires to the alternator plus feeds any light switch. Ifffff fff its really a 100 amp alternator and Ifffff ffff you wanna fully utilize it, you need bigger wires n a bigger rated/scale ammeter. If so, I would install a 6 Gauge wire from the Alternators big main BAT output stud up to the Ammeters Load (NOT to Battery/Starter) terminal,,,,, ,,,a 6 Gauge wire from the Ammeters other Supply terminal down to the starter switch or solenoid where the big battery cable is attached. The Ammeters Load side terminal also needs a wire to feed any lights or a light switch, but the exisitng or a new 12 Gauge woud be plenty there. 4) If it has an electrical starter solenoid instead of a mechanical push to start switch, that would have to be chnaged to a 12 volt solenoid. If its a push to start mechanical starter switch, no change needed. 5) Change any light bulbs to 12 volts. 6) The Mag gets no battery voltage input so its not a problem. If its a Wico X that has the external kill switch stud, all you need is a 14 gauge wire from it up to a dash push/pull or Toggle SPST ON/OFF switch and if you connect the kill stud wire to frame ground it kills the spark. Nuff said, Good Luck n God Bless Ol John T in Indiana
