18.4 X 34 on a JD720D?
freddy
09-22-2005 12:33:02
Has anyone put 34 inch cast hubs on a jd720? Is it possible? I have a set of good 18.4 x 34 tires and would like to use them. The rims on the old tractor are severly corroded and I found one cast wheel broken. Would like to keep the hurt to a minimum. Would the rims from a 4020 or a 3020 fit? Any ideas would be help full
JDBert
09-22-2005 13:57:34
 Re: 18.4 X 34 on a JD720D? in reply to freddy, 09-22-2005 12:33:02
720's had 3 1/8 axes so, you would need to find 4010,4000 or 3020 cast. Your best bet is gonna be the 4010 or 4000 because I dont think 34" was a option on the 3020. ORRR you could go with a pressed steel setup if you had the hubs and rims.
Doug in IL
09-22-2005 18:46:10
 Re: 18.4 X 34 on a JD720D? in reply to JDBert, 09-22-2005 13:57:34
Also the 4030. 3 1/8 axles and most of them had 34 inch wheels.
CMB
09-22-2005 16:01:04
Yes, 34" wheels were an option on 3020's I had a neighbor who bought a new one with 16.9x34s on it. Also, my dad bought one of the last 4010D's that was sold in our area. It had 15.5x38 rubber on it from the factory, but Dad specified it must have 18.4x34 wheels. The dealer ordered a 4020 with those wheels, only to discover that the 4020's axles were bigger. He then had to order a 3020 with heavy cast 34" wheels & 18.4x 34 rubber to equip our tractor in the manner specified in the sales contract!
freddy
09-22-2005 17:34:54
 Re: 18.4 X 34 on a JD720D? in reply to CMB, 09-22-2005 16:01:04
Thank You very much for that info. Now all I need to find is a salvage yard that has some.
