JD #5 mower weight
PeterE
09-22-2005 09:14:34
Does anyone have a rough idea of what a Deere #5 mower weighs? I'm wondering if I could put it in the back of the pickup or if I should use a trailer.
Soldier Tom
09-22-2005 17:25:49
 Re: JD #5 mower weight in reply to PeterE, 09-22-2005 09:14:34
I hauled one home in the back of a short bed F150. NO PROBLEMS. Put the tail wheel in first, cock it sideways a bit, don"t use the "landing gear" and ratchet the frame down to the bed. I would screw another nut onto that tail nut on the cutter bar, just in case it vibrates loose on the road and drops the bar. Not only would it damage your truck, it would be a shame to loose the tailnut as they are not readily available ANYwhere I"ve seen.
~Walk in peace~
Soldier Tom
Bob
09-22-2005 09:21:51
According to the operator's manual, the shipping weigth with a 7' cutterbar is 690 lbs..
If you can knock the hinge pins out where the cutterbar pivots at the inner shoe, and remove the cutterbar from the mower frame, the 2 parts are easy to haul in a pickup.
john tabor
09-22-2005 13:44:35
 Re: JD #5 mower weight in reply to Bob, 09-22-2005 09:21:51
if you have access to a front end loader and a couple of good chains and binders you can haul it as it is. it just sticks up in the air so its a little top heavy so tie the top off well. never ever grab the cutter bar with your hand around it. alwasy keep your hand open and flat against any part of the blade. it can slide down when you stand it up and slice off some good stuff.
