3010 load shaft/axle
Ed Tate
09-22-2005 07:09:21
Less than a year ago I put new bushing and seals in the old 3010. They were not tight as the case has suffered some wear. Now I once again have an automatic if unwelcomed tranny drain happening.
What about disabling the load sensing function by making wider, tighter bushing and putting them in with good ole JB Weld?
Once I read something about an aftermarket fix, better than JD.
Any tips on getting wheel wedges to grip better? Got everything clean and in good shape but the wheels won't stay put.
Any ideas? Thanks,
Ed
mAARK
09-22-2005 21:03:37
 Re: 3010 load shaft/axle in reply to Ed Tate, 09-22-2005 07:09:21
those three large bolts need to be torqued to 300 FT. LBS.
HTR
09-22-2005 20:15:55
A&I has the load shaft bushings for the 3010 in standard, .003, .006 and .030 over size
matthies
09-22-2005 18:58:50
While working at a Deere dealership I did glue the bushings in with a Deere product called Liquid Steel on a 4030. This was in a farmers shed. He had problems before and knew they were loose. Never got called back to do it again. I told him not to use the tractor for two days or so and not to put the oil in until then. Also Deere has a tool to cut new bores in your rearend casting if all else falls. This tool goes from dealer to dealer around the US as needed, I was told. And might be a waiting list to use also. Good luck chris
Bob
09-22-2005 08:16:53
Boling machine
Mike M
09-22-2005 07:39:53
I was thinking JD sells oversized bushings. On that wheel wedge you may need to buy a new one or get some used ones. You could also slip a piece of shim stock in there to snug things up.
Huckleberry
09-22-2005 07:32:24
I am not familiar with the 3010...but I think they are similar to the 3020. I have same problem with load shaft on my 3020 and have wondered about disabling that function ~ but probably will not. Curious if you find any info in that regard. Please inform. As to wheel slippage---I don't know but you must be doing something backwards...I have never encountered that problem.
