2010 open or closed center hyd.
JD guy
09-21-2005 22:00:57
Am installing a front loader on a 2010 utility. Need to know if it"s open or closed center so as to have correct valve installed on loader. It has a gear type pump in belly, no front pump.
buickanddeere
09-22-2005 08:57:17
 Re: 2010 open or closed center hyd. in reply to JD guy, 09-21-2005 22:00:57
Open center gear pump. Don't worry, deere exectives forgot or didn't know about the 2010 during the late 1980's early 1990's. They tried to build another 2010 with the 5000's and 1st 1/2 of the 5000 Ten series.
Bob
09-21-2005 22:18:33
Open center.
txgrn
09-22-2005 03:53:59
 Re: 2010 open or closed center hyd. in reply to Bob, 09-21-2005 22:18:33
Did mother deere do one type on the smaller tractors and a different design on the larger ones? My 4010 and 4020 use a closed center hys system. My Fords have open centers on all the sizes I have (small and larger....not the largest....dunno on that).
Mark
msb
09-22-2005 20:50:15
 Re: 2010 open or closed center hyd. in reply to txgrn, 09-22-2005 03:53:59
It was no secret at Deere .The best of the best engineers were hired for development and production of the New Generation at the Waterloo plant 3010,4010 & 5010 tractors.Up to that point the top engineering grads had been hired by GM, Ford and Chrysler.The neer do wells worked at Dubuque (sp?)Management knew where the market was headed and it wasn't in small tractors.Time proved them correct.Deere's top management genius also put the hurt on all other farm equipment manufacturers.
jdemaris
09-22-2005 05:33:36
I worked on a lot of 1010s and 2010s when they were new. It appeared to me that Deere was using up left over - almost obsolete parts to build them. What a mess! Especially the industrial wheel tractors. Not counting two cylinder tractors, German utility tractors (e.g. the 820-830), or Japanese Yanmar tractors (e.g. 750, 850,) I think the 1010 and 2010s were the only tractors that used open-center hydraulic systems with gear pumps.
