755 hydraulics
Scott in MD
09-21-2005 19:04:06
I have a 1990 JD 755. I have trouble with the 3 point hydraulics lowering. They never have a problem raising, but when I try to lower, they sometimes freeze. They will eventually bleed down very slowly. I disassembled the drop/lock valve thinking it was stuck. This solved the problem for a while the first time, but now the problem is more persistant, and returns after a short time. When I disassemble the valve, it has pressure locked in, even with the rockshafts lowered. I finally removed the guts out of the valve to complete a job, but would like to solve the problem. The valve appears to be in good shape. The JD dealer thinks the valve is just a way around the true source of the problem.
Thanks for any help you can provide.
