Hey jdemaris question for you
mitchp
09-21-2005 08:13:53
Hey jdemaris, i put a T handle destroker valve on my hydralic pump on my 2120 JD. it worked great for awhile but then when i would start the tractor and unscrew it, a little bit of hydralic fluid would come up between the threads but stop. I had some problems with the 3 point hitch not wanting to lift at all too but only at certain times though, my power steering would get really easy to steer, still had brakes though. usually 3 passes with the bushhog, or pull type harrow would make the lift or hydralics quit. So i put the dummy plug back in the pump, that didn't help any, my uncle said to put the t handle back in, screw it in and out while the tractor is runniing, which i did, and the pump came on, lift started working instantly, my guess is i've got a small bit of metal in the hydralic fluid thats causing it to destoke at times. when it gets to the pump, it gets caught and makes it destroke. Sound logical to you? ever had the problem before??? ideas?
