Front end bushings 1520
Mark Westphal
09-21-2005 05:06:57
I need to change the front end pivot bushings on my wide front 1520. Is there any secrets I need to be aware of to get started. I will definately block up the tractor and try to be as safe as I can. Should I remove the tires and wheels to make the front pivot plate lighter?
Any suggestions would be greatly appreciated.
Mark
K.B.-826
09-21-2005 20:40:43
 Re: Front end bushings 1520 in reply to Mark Westphal, 09-21-2005 05:06:57
I did one a few months ago. I took the wheels off to get more clearance for lowering the front end and to make it a little easier to work on. I think I put a heavy jackstand under the clutch housing and lowered the front end with a floor jack. I needed my air hammer to knock one of the pins out. A torch is the easiest way to remove the old bushings, but I wouldn't suggest doing that on the bushing in the casting under the gas tank. Better put new pivot pins in as long as you've got it apart.
lonzo
09-22-2005 17:48:40
 Re: Front end bushings 1520 in reply to K.B.-826, 09-21-2005 20:40:43
it's a job putting the front axel back in because the front and rear pins half to go in an the same time, if you scare a bushing then you really got troubles, use a bushing driver for sure, i like to use a welder bushing, bearing races, dry engin sleeves, they shrink with welding and makes the job a lot easer, to save money find a A&I parts dealer and see if he can get the things you need have fun
