IH guy needs a little JD help
JT
09-20-2005 16:38:04
I have acquired this part,The part numbers are it are:F517A and F518A. It has a JD cast in the part, that is why I am over here buggin you guys, not sure what I have, just curious. Been told it is a clamp to hold an umbrella, but before I tell people what it is, I thought it is time to ask the experts.
leon
09-21-2005 04:03:19
 Re: IH guy needs a little JD help in reply to JT, 09-20-2005 16:38:04
Welcome, IH guy. This JD guy has been dabbling a bit on the IH side lately as well! Maybe it's a JD "H" and the hootus on the dash is the shutter control.
Ralph - Ohio
09-20-2005 17:51:04
If you do a Google search for John Deere F517A or John Deere F518A you'll find a couple different pictures and descriptiuons calling it an umbrella bracket. One is priced at $90!
JT
09-21-2005 08:22:50
 Re: IH guy needs a little JD help in reply to Ralph - Ohio, 09-20-2005 17:51:04
Ralph,
I did the google search, lo and behold, the one picture for $90.00 was exactly what I have. Thank you
Jim
txgrn
09-20-2005 17:44:14
Would like to be neighborly and all beins you are a red guy over here and the green guys have this reputation for being stuck up and all (Grin) but I really don't know.
I have a couple of greens and both have some kind of hootus on the dash with a twist cap on it and I can't figure out what it is..... but it's not a holder for an umbrella....at least I know that much.
Wish you luck
Mark
silly Guy
09-20-2005 20:17:18
 Re: IH guy needs a little JD help in reply to txgrn, 09-20-2005 17:44:14
That cap screws off so yous can put up a cans of that nitro to helps start that darn motor
txgrn
09-21-2005 18:14:52
 Re: IH guy needs a little JD help in reply to silly Guy, 09-20-2005 20:17:18
Thanks,
I know that now.
Mark
Bob
09-20-2005 18:59:32
third party image
Like this ether injector, or is it an older tractor with a shutter control knob that is kinda like a big wingnut you twist?
txgrn
09-21-2005 18:13:49
 That's it in reply to Bob, 09-20-2005 18:59:32
Ether injector.
Thanks Bob.
The hose and all that stuff is gone, otherwise I should have been able to recognize it.
Mark
Bob
09-21-2005 21:45:41
 Re: That's it in reply to txgrn, 09-21-2005 18:13:49
TX,
If the steel line from the ether injector to the intake manifold is missing, be sure the hole where it used to connect to the intake manifold is plugged, so the engine isn't sucking in dirt!
txgrn
09-22-2005 04:06:08
 Re: That's it in reply to Bob, 09-21-2005 21:45:41
I'll look. Thanks,
Mark
Mark Scholten
09-20-2005 18:45:13
The hootus on your dash could very well be the dash light deflector. Is it cut out on the bottom? The bulb shines down on the gages instead of in your face.
Mark
