4020 battery boxes interchangeable
Shawnand Heathe
09-20-2005 15:25:24
My battery boxes on my 1970 4020 are badly rusted through. A friend has two from a 1968 he will sell me fairly cheap. I know the part number are different, but could a guy make the old boxes work? They look the same as mine form the picture he emailed me, hard to tell about the brackets though. Thanks all
Glen in TX
09-21-2005 09:15:18
 Re: 4020 battery boxes interchangeable in reply to Shawnand Heather, 09-20-2005 15:25:24
BTW the aftermarket boxes came with 2 sets of brackets. I found the others hanging on shop wall today.
lonzo
09-20-2005 16:17:20
no the brackest are differnt
twopop
09-20-2005 16:16:59
I dont know much about it.that said,a friend needed both boxes for a 4020 he bought,also needed brackets.he bought some after market boxes and brackets.anyhow,they wouldnt work.apparently a synchro takes differant brackets than a powershift,and the boxes are differant.me thinks you should put the right # boxes on
Glen in TX
09-20-2005 17:48:52
 Re: 4020 battery boxes interchangeable in reply to twopop, 09-20-2005 16:16:59
The brackets will be some different. You can cut them off and reweld or bolt them back or get the right boxes. The aftermarket boxes have adjustable brackets to fit 2510 - 4620 for row crop models without cabs but will work for some with add on cabs also. I put some aftermarket ones on a 2510 and once I got brackets lined up and bent holding levers some to latch right they worked fine.
