60 trans kicking out
Chrisfromsolitude
09-20-2005 15:16:06
My 1953 60 will kick out of gear when it rolls down a hill. The shift lever stays in place on the shift quadrant but the tractor acts like its in nuetral. You can disengage the clutch and put it in another gear and it will move again. How ever you can not put it back in the same gear. It only comes out of gear when you roll down a hill and the engine is faster than slow idle. When the transmission starts to roll forward it will just start freewheeling and you got nothing. No gear grinding is heard either. The clutch is tight and the PTO still works. Anybody had this happen or know where to start? Thanks
Cowboys013
09-21-2005 14:52:04
 Re: 60 trans kicking out in reply to Chrisfromsolitude, 09-20-2005 15:16:06
It sounds like the overdrive gear is popping out and lock up your shifting tower. You probably need a new pawl, pawl spring and maybe a shifting rail that the pawl engages into or worse, a new stub shaft with gear and overdrive gear. The only way to see which you have is to tear it down and look.
