Rear wheel adjustment
Big 3010
09-20-2005 09:53:35
I am trying to move the cast rear wheels outward on the axles several inches on my row crop 3010 and am having some problems. I have loosened the three tension bolts and ran in the two jack bolts on the pinion side of the wheel but the wheel seems seized to the axle. The pinion bolt only turns about 1/4 in. left or right, then stops. I have sprayed a good bit of penetrating oil into the pinion area and all around the half sleeves and let it soak in. I hate to get too rowdy with an impact or with heat around the axle and cast wheel. Any suggestions?
Rodney A. Johnson
09-20-2005 10:33:34
 Re: Rear wheel adjustment in reply to Big 3010, 09-20-2005 09:53:35
I suggest loosening the other three tension bolts...there are three on each side if I recall correctly. Then do as Mike suggested.
There are some other suggestions if you do a search on this web site. There was a dicussion a month or so back on this very subject. There were one or two who were quite adamant about NOT using the sledge hammer method. They had some suggestions that sounded like they may work well.
From personal experience the sledge hammer method has always worked for me. Have used it on a 3010D and a 4020D multiple times. I used the method because that is what a JD technician suggested many years ago to my dad. It was what that particular technician/dealership used to move the wheels on 10 and 20 series.
I must warn you though, not to use this methods on JDs prior to the new gen 10 and 20 series...it can cause damage (from same JD technician).
Mike M
09-20-2005 10:25:25
Keep the tension on the jack screws,careful you don't go too tight and strip them out.Then get the biggest sledge hammer you have and whack the end of the axle hard and square a few times.
