430 hydaulics
Walker Dogs
09-20-2005 08:19:41
I"ve got a 430 JD and the hydaulics quit working. We took a line off and shot fluid about 100 ft. So I"ve got pressure right? What else should we check? Thanks in advance for your advice. PS the fluid is full.
Safety Watcher
09-20-2005 20:16:29
 Re: 430 hydaulics in reply to Walker Dogs, 09-20-2005 08:19:41
Geez Lonzo, what are you thinking? !!!!
That's the fastest way I know to loose a thumb, finger or eye. He's already said it sprays out 100ft.
lonzo
09-20-2005 16:31:10
there are all kind of things can go wrong and you might half to get a book for the repairs. now don't look for big things look for small things like a pin broken some linkage broke or rusted shut. pull coil wire so it won't start and remove the pressure line [this is crude ] and hold your finger and see if you can stop the oil pressure when you are cranking engin, if you can something is wrong in the pump if not got to the lift houeing and start looking
