JD 212 transmission popping out of 3rd gear
Doug M
09-19-2005 18:20:50
My 1975 JD 212 pps out of 3rd gear once and a while. Has anyone used redline gear oil or recommend it? Thanks for your time.. Any input would be greatly appreciated.
always,
Douglas Murrray
Maark
09-20-2005 14:31:34
 Re: JD 212 transmission popping out of 3rd gear in reply to Doug M, 09-19-2005 18:20:50
The reason it pops out of gear is that the detent spring on the shifter shaft is broken. The transaxle will have to be removed and split to replace the .50 cent spring.
Doug M
09-20-2005 19:26:44
 Re: JD 212 transmission popping out of 3rd gear in reply to Maark, 09-20-2005 14:31:34
3rd gear only pops out when running...not when shifting.... I tend to think it is not the shifter mechanism. Correct me if I"m wrong. dlmrun2002 @ aol dot com
