JD 35 Harvester
PJBROWN
09-19-2005 16:34:02
I just got a JD 35 chopper in real good shape. It has a 5 foot hay head and a 1 row corn head. I put the corn head on and try it out. It used all most no power and cut real fine and uniform ,but it feed into the cutter head slow. I could not go over 3 MPH or I would over load the corn head. The question I have is would the 35 handle a 2 row head ??? I think a 2 row head would fit it ,but I don't know if the harvester would have the capacity too handle it.
David from Kansas
09-19-2005 20:09:14
 Re: JD 35 Harvester in reply to PJBROWN, 09-19-2005 16:34:02
Yes, a two row head is available. There are 4 model 35's in machinefinder.com, and two of them are equpped with 2-row heads. They are available in narrow (30") or wide (38") configuration. If your 35 is like my 38, the length of cut is ajustable, from about 1/4" to about 1" if I remember correctly. The longer you make the length of cut, the more capacity you will have as the cutter has to do less cutting with the same amount of material. With the model 38, about 2-4 MPH is about maximum. Off course, when it was new 35 years ago, it did a little better.
