3 bottom 3 point plow questions and concerns
jd50_tye
09-18-2005 17:42:37
My dad has this 2 bottom Worksaver brand plow that hes had for years. Its just a cheap run of the mill 3 point hitch plow without coulters or a tail wheel. About three weeks ago I decided that I was tired of seeing this plow sit in the shed unused. I am going to add another bottom to it along with coulters and a tail wheel. I am also going to add more steel to it by using tubular steel to reinforce the existing frame. I have all the parts and steel to make it all happen. This is where it gets a little technical. When I add another bottom, does that change the center draft point on the plow? At first thought I said it would- but looking at plow pictures on the internet, I've come to the conclusion that in both the 2 and 3 bottom plows the 3 points to hitch the plow up are in the same exact locations in relation to the main beams. Go to the link and look at the plow in the picture. You'll notice that the outside pin for the 3 point is at the same location as it would be if the plow was a 2 bottom. Here is a few quotes from my JD 50's Operator's Manual, "The ideal hitch is a straight line from point of resistance on the plow to point on the tractor, both horizontally and vertically." Further down the page, "SET REAR WHEEL TREAD WIDTH. Normally, before the tractor rear wheels can be set correctly, it is necessary to locate the center line of draft of the plow. This is determined by using the following rule: The center line of draft of a moldboard plow is located at a point one-fourth of the cutting width of one bottom measured to the left of the center of total cut of the plow." If this is true then the center line of draft of a 3 X 12inch plow is at 21 inches from the furrow wall. The center line of draft on a 2 X 12inch bottom should be 15 inches from the furrow wall. There's a difference of 6 inches. So this means I should move the 3 points on the plow over 6 inches from where they were to accomodate the change in center of draft by adding the extra bottom. Does all this sound right? Thanks for any thoughts.
RalphinWI
09-18-2005 23:02:48
 Re: 3 bottom 3 point plow questions and concerns in reply to jd50_tye, 09-18-2005 17:42:37
In the picture I see two red plows (2 & 3 bottom)which I presume you are comparing. From what I perceive, the hitch bars span 2 and 3 plow beams, which would account for the shift of the center of draft from 15" to 21" from the furrow as one switches from 2x12" plow to a 3x12" plow. This would suggest inside spacing of the rear wheels of the tractor of 30" and 42". Warning! -calculations were done as I typed after midnight.
